Kolik % zatmaveni maji predni bocni okna z vyroby?
Re: Kolik % zatmaveni maji predni bocni okna z vyroby?
E v kroužku s číslem udává ve které zemi EU bylo homologováno - např. ČR má 8, takže E8 - homologováno v ČR.
aktuálně:
Hyundai i30 kombi 1,6i CVVT
Škoda Yeti 2,0 TDi 4x4
v minulosti:
Škoda 120L; Škoda 100L
v minulosti:
pri i30tkach presli na ine oznacovanie, ako pri starsich modeloch, kde to udavali ciselne v %.
AS1 az AS3 urcuje priepustnost
podla obrazkov mas vpredu AS1 a na bokoch AS2, cize priepustnost najmenej 70%. ci je priepustnost 71%, alebo 99% asi nezistis, jedine meranim.
osobne by som sa na folie vpredu vykaslal...
mozno by stalo za zvazenie si kupit alarm s dialkovym startom a 10min pred odchodom nastartovat auto, aby ho klima vychladila
zdroj: http://www.delica.ca/forum/window-glass ... -7654.htmlThe AS number stands for American Standard, and is "AS" (or "American Standard") followed by a number indicating the position in which the glass may be used, based on its optical quality.
- AS1 is the clearest glass (at least 70% light transmission), is laminated, and can be used anywhere in a motor vehicle (typically just the windshield)
- AS2 is tempered with at least 70% light transmissions, and can be used anywhere except the windshield,
- AS3 can be used in certain locations in certain vehicles (and can be laminated or tempered, and has less than 70% light transmission). There are higher numbers used for other purposes, but are not normally encountered in cars. This number must be near the manufacturer's name/logo, preferably below it (per Z26.1996).
Ja jsem dopredu uz folie nedal, jednak z duvodu ze chci aby to vyhovovalo vyhlasce a jednak ze zkusenosti z minuleho auta, a to ze kdyz se setmi nebo je sero,pripadne prsi,tak jde v zrcatkach hodne spatne videt pokud mas folie...
Odesláno z mého GT-I9100 pomocí Tapatalk
to je sice pravda s tema brylema ale vecer bryle nenosim takze ten problem nemam
bryle jsou prima vec, ale nesmite nosit dioptricky, jelikoz jsem nikdy bryle tim myslim slunecni nemel rad, na dioptricky jsem si musel zvyknout tak delat si co 2 roky novy slunecni dioptricky bryle kdy das za jedno sklo treba 3000 a za tohle mas pomalu folie na cely auto, tak pak opravdu radsi ty folie...
bony:
a klidně i dvoje, že?
t0x!n: to já raději brýle s kvalitními "skly", antireflexem a polarizačním filtrem, ideálně v akci, kdy je jedno sklo grátis
máš ale pravdu, jedny kvalitní brýle stojí o hooodně víc než kvalitní fólie na všechna okna na auto
Lehce OT
Já dal za brýle 7 000 z toho cca 2000 je za obroučky (nějaká akce 50% sleva) a skla tedy 5250 - mají všechny vymoženosti, co se nabízejí
Opravdu někdo dokáže za cca 5000 "ofóliovat" celé auto ??
Peugeot 207 SW (2008) - firemní kára
Škoda Fabia 1,4MPi (2001) - manželky
Re: Re: Kolik % zatmaveni maji predni bocni okna z vyroby?
Asi mas dost levna skla moje bryle byly za 15.000,-Demonicus píše:Lehce OT
Já dal za brýle 7 000 z toho cca 2000 je za obroučky (nějaká akce 50% sleva) a skla tedy 5250 - mají všechny vymoženosti, co se nabízejíOpravdu někdo dokáže za cca 5000 "ofóliovat" celé auto ??
odeslano z telefonu.
Tak ja teda nevim, asi se koukam vsude kde to je pod cenou
komplet bez celniho skla folie i s praci vyjdou na 3500-4000...
Jj souhlas s toxinem taky muzu mit za 3500 komplet folie na kombi bez celniho samozrejme
Pro porovnání:
- kolegyně nechávala tónovat Octu II v rozsahu zadní dveře + okno na pátých dveřích za 1500,-
- v Přerově tónování od 2000,- (dle cedule u silnice)
- moje poslední brýle stály cca 10000,-, v ceně zahrnuta sleva 50% na skla
