Imobilizer (kody, problemy)
69pavel
Re: Kod od immobilizera
Příspěvek od 69pavel »
mi menili antenku a kdyz jsem chtel po nich kod ,tak mi ho nechteli rict,spis nemohli,udajne je to program z ameriky nebo z canady a vozy ktere jdou na tamni trh tak maji napsany kod v servisni knizce nebo nekde na stitku a tady u nas kdyz spravujou imobilizer tak volaji nejakeho typka z prahy a jak ten typek prijede tak se online napojuje do canady a stahuje ten kod imobilizeru. takhle mi to vysvetlili v Ostrava Mar.hory tak nevim co si o tom mam myslet 8)
miro263
Příspěvek od miro263 »
Zaregistroval som sa na: http://www.hmaservice.com/
A docital som sa toto ( vid priloha) Je to pre Azeru, ale asi to bude to iste
DESCRIPTION
The 2006 Azera is equipped with an Immobilizer passive security system. The
Immobilizer prevents the vehicle’s fuel injection system from operating and starting the
vehicle unless the correct pre-programmed Immobilizer key is used. The Immobilizer
system is also equipped with a programmable 4-digit password to enable a ‘Limp
Home’ mode. In the event of an Immobilizer system malfunction, this ‘Limp Home’
mode will allow the owner to start the vehicle by entering their pre-selected 4-digit
password using a series of ignition key cycles (i.e., On-Off). This ‘Limp Home’ mode
provides an alternate means for the owner to drive the vehicle to their authorized
Hyundai dealer for system servicing. This ‘Limp Home’ mode and related procedure is
described in the 2006 Azera Owner’s Manual.
Additional information on recognizing, diagnosing, and correcting Immobilizer-related
faults can be found in the 2006 Azera Shop Manual.
NOTE: This feature is disabled from the factory and there is no default code. The
customer-selected 4-digit ‘Limp Home’ password must be programmed
into the Power Control Module (PCM) during the vehicle sale process
using a Hi-Scan Pro diagnostic tool.
NOTE: The 4-digit ‘Limp Home’ password is different than the 6-digit PIN code
used for the Immobilizer key ‘Teaching’ function. The 4-digit password is
not permanently associated with the VIN and may be accessed and
changed at any time using a Hi-Scan Pro diagnostic tool.
Je tam aj postup ako na to.
Upol som to tu: http://uloz.to/2410617/06-90-009pdf.pdf
Hyundai Accent MC 1.4 -city car
a kopec dalsich nehyundaioidnych
Rudolf
Příspěvek od Rudolf »
Tak mi dneska "přečetli" auto a výsledek: vadná cívka imobilizéru - objednaná nová - výměna v záruce.
Na dotaz ohledně kódu imobilizéru mi bylo odpověděno, že u nových aut už "finta" s zapínáním a vypínáním klíčku není možná. Z bezpečnostních důvodů se ke kódu nedostane ani servis. Při nakódovávání nového klíče se spojí po internetu s jakýmsi počítačem a ten on-line nakóduje imobilizér.
Hyundai Atos Prime 1,1i;
Hyundai Accent Elegance 1,6i CVVT;
cert
Příspěvek od cert »
No, tak naše auto je vyrobený někdy v červnu 2008 a na klíči mám nálepku s nějakým kódem (2 písmena a 4 číslice) - ovšem na co to je mi prodejce teda neřekl - natož aby dal instrukce jak to v nouzi použít...
Martun
Příspěvek od Martun »
CERT: To máš asi stejný co já a Vilda a asi mnozí další. Jak to vypadá tak je to číslo celkem naprd. Jak jsme se shodli s Vildou, vypada to že jsou identicky...
Takže když už nejde ten fór s vypínáním a zapínáním ve spínací skřínce, to si to auto v případě potřeby, NEDEJ BOŽE!! mám jako naložit na záda a utíkat s ním do servisu?? By mě zajímalo, kde soudruzi udělali chybu... [-o<
miro263
No podla mna su lenivy updatnut uzivatelsky manual a odstranit dezinformaciu.
cert
Příspěvek od cert »
Martun píše:CERT: To máš asi stejný co já a Vilda a asi mnozí další. Jak to vypadá tak je to číslo celkem naprd. Jak jsme se shodli s Vildou, vypada to že jsou identicky...
Ta nálepka s kódem je bílá a jen na jednom klíči - tu žlutou jak tady byla fotka, tu tam mám samozřejmě taky (na obou klíčích). Kdoví na co to je....
Martun
Však se nato zeptám až se dostanu do servisu. Ja mám fakt jen ty žlutý samolepky... :cry:
adam221
Příspěvek od adam221 »
Martun píše:Však se nato zeptám až se dostanu do servisu. Ja mám fakt jen ty žlutý samolepky... :cry:
Tie zlte uz nemam ani ja... Odlepili sa :(
Mercedes W212 350cdi
Clio V PH2
Citroen C15d
Martun
adam221 píše:
Nemusíš smutnit, vypadá to, že jsou stejně naprd, nám obyčejným uživatelům naprosto k ničemu..
69pavel
Martun píše:
adam221 píše:
to cislo u tech klicu je cislo klice v pripade ze stratis klic tak ti v praze vyrobi klic druhy a podle toho cisla na tom stitku ti ho nakodujou. v pripade ze ti kodovali klice jak mne tak ten stitek je naprd(novy stitek s cislem mi nedali)
palčo
Re: Občasný problém se startováním
Příspěvek od palčo »
Tak dnes mi to tiež nechcelo naštartovať. Stalo sa mi to asi štvrtý krát v priebehu dvoch mesiacov. Zajtra volám servis. :-k
HYUNDAI Accent, 1,4 Dynamic-Gold beige
palčo
Tak som dnes volal do servisu, môže mať na to vplyv aj keď nosím kľúče pri mobile, alebo nejaké magnetické čítačky v obchodných domoch-asi tie cez ktoré sa vychádza z obchodov. Doporučili mi vymeniť kľúč, a keď sa to bude opakovať, mám prísť do servisu s oboma kľúčami a (samozrejme) s autom, a oni to nejako spárujú.
:-k
xwing
Příspěvek od xwing »
No to s tým že kľúč nemám nosiť pri mobile, dávať k mikrovlnke atď. ma upozorňovali pri predaji, taktiež to je myslím v manuáli. Pre istotu mám kľúče :hyu: vždy v opačnom vrecku ako mobil.
Hyundai Accent 1.4i Dynamic - Wine Red (05/2009)
palčo
Ja kľúče síce nenosím pri mobile, ale aj tak ma nenapadlo, že to môže škodiť. A ja "manuálový človek", som to v manuáli veru nečítal. ](*,) :roll: :-k [-o< Ale ako som zavolal do servisu, tak mi to prestalo robiť. Aspoň zatiaľ. :D/
