P1181
P1181
Prosim o radu mam hyundai Trajet 2,0 CRDI a neco zacalo zlobit nekdy jezdi uplne normalne a nekdy mu hrabne a proste pri jizde chcipne treba i opakovane diagnostika pise P1181 sledovani tlaku paliva, Palivovy filtr vymenen a regulator tlaku paliva taky ale zlobi porad
Re: P1181
https://www.engine-codes.com/p1181.html
P1181 Possible Causes
What does this mean?
Restriction in the fuel line
Plugged fuel filter
Faulty Fuel Pressure Regulator
Faulty Fuel Rail Solenoid Shutoff Valve
Fuel Rail Solenoid Shutoff Valve harness is open or shorted
Fuel Rail Solenoid Shutoff Valve circuit poor electrical connection
Mam sluzobny Opel Astra 7 rocny, 1,7 diesel, najazdene 152tis. km a auto mi padlo do nudzoveho rezimu pri priradovani sa na dialnicu (=slabo tahalo). Mal som podozrenie na merac prietoku vzduchu. Auto slo do servisu, najskor vymenili regulator tlaku paliva. Po oprave som presiel cca 60km a auto padlo opat do nudzoveho rezimu. Auto slo opat do servisu. Vymenili vstrekovace paliva a auto zatial funguje. Lacne to teda nebolo (regulator a vstrekovace). Ako bonus mam, ze mi klesla spotreba.
Plugged fuel filter
